Will xps polystyrene foam board insulation react with wood that is coated with spar urethane? Will the foam board melt?
You should check with the manufacturer of the foam board for a definitive answer, but I can't imagine any circumstance where styrofoam would interact badly with a cured finish. (Urethane is pretty inert when dry.)
