I have an older Gerber brand toilet. The black rubber seal that looks like a Mason jar lid is crumbling and turning into black goo when touched. Is it easy to replace this? What is the purpose of this part? Will an American Standard one fit on a Gerber? Is there a way to keep these from disintegrating? Any help with information on this part would be appreciated. Thanks.
Hello, and welcome to Stack Exchange. Where is this seal? – Daniel Griscom Jul 25 '16 at 16:10
In the toilet tank at the very bottom, in the center, under the rubber flapper that opens and closes when it is flushed. – Carol Jul 26 '16 at 18:48
It's unclear exactly where this seal is without pictures, but in general they are all replaceable, ease of replacement varies (sometimes you have to take the tank off the toilet to replace seals), and you had better try to find one made for your specific brand/model of toilet, as between manufacturers there are often incompatibilities. An actual plumbing supply may have a better selection of parts than a big box store.
Some replacement seals are offered in a "chlorine resistant" rubber formulation (often red) but in general, rubber at 30-50 years old does simply tend to fail from old age. If you are one of those people that puts an extra-chlorine "toilet cleaner" in your tank, you might expect to have faster aging of rubber and plastic parts as a result. Even if you do not add extra chlorine, they do not last forever.
