This fixture happens to be plastic, but all my ceiling juntion box mounted 600w rated light fixtures have a removable collar. I don't see the point in this extra part. Is there some sort of shade I can install? I assume if you had a heavy bulb that you'd just use an E39 size socket instead of the E26 socket.
Removed collar
    I'm used to seeing those when there is a shade or something to attach, but I also wonder what role it would have in insulating the plastic base and wiring it covers from heat generated by an incandescent bulb. Jul 21 '16 at 19:59
  • 4
    It holds the socket into the fixture on the original porcelain fixtures, and as mentioned it can be used to attach a shade or reflector.
    – Tyson
    Jul 21 '16 at 23:56
  • Did you mean 600W or 60W ? Jul 24 '16 at 12:01
  • 600 watts. The ceramic ones are rated for 600 watts Jul 24 '16 at 13:07
  • What is the application of this bulb? Googling 600W turned up lights for plant growing? Jul 24 '16 at 13:22
-1
It looks like the metal screw socket would be touchable without the plastic ring in place. When the bulb is lit, I believe that would be hot (energized).
Since they may use the same base for different size screw fittings, the ring is possibly designed to protect from shock hazard but being a separate component allows the base to accommodate various sized sockets.
The specific scenario I can think of when this would be important is when screwing in a new bulb to replace a dead one. The circuit could unknowingly be on (since the bulb is dead), and you could get a shock when the bulb made the circuit.
  • Wired correctly the shell would never be hot, only the small tab in the middle. It is also not desigend for different sized sockets. An edison socket is an edison socket (in North America at least). Jul 23 '16 at 13:56
  • The socket would be electrified when A) the circuit is switched on and B) a functional bulb is screwed in. If it were not, there would be no way to complete the circuit from the tab in the middle. Granted the tab is wired to the switched live wire (in 120V single phase) but you could still get a shock from the neutral when the lamp is on. If it were in a 240V single-phase or perhaps 3-phase then it would be the same situation but of course there is no neutral. Jul 24 '16 at 2:15
  • Also, there are several common sizes of ES sockets in the USA, not only one. The OP even mentioned a few types. I've seen larger variants for like a large sodium-style bulb (not sure of the exact type / terminology) and obviously there are the smaller ones for say candelabra type bulbs. These are all Edison sockets; seems plausible to me a base such as in the question could accommodate any of those variations. Jul 24 '16 at 2:17
  • No, if wired correctly the shell would NOT be "electrified". That is the whole point. And in a residential setting there is no 240V lighting, so again, the shell would not be live. Jul 24 '16 at 11:21
  • And sorry, I should have said medium base socket, not Edison socket. This is a typical keyless fixture. They come in medium base. Not mogul, not intermediate, not candelabra. Jul 24 '16 at 11:22
