It just occurred to me that if I install a ductless heat pump to cool the air in my house's bedrooms in the summer, the unit will be cooling and dehumidifying the air - but not introducing any new oxygen. The window will also be closed. If I spend a few hours in one of the rooms, is there a significant chance of CO2 buildup which could cause malaise and tiredness? The bedrooms are relatively small, about 3 metres by 2 metres each.
    Homes with electric cable heat & base board units don't have makeup air and I have never heard any issues there. – Ed Beal Jul 21 '16 at 18:47
  • Opening windows once a day for 15' is enough to refresh air without wasting much energy. Anyway only CO2 buildup will be human-breath related so, there's no 'healt' risk, it's just a matter of improving the environment. – DDS Jul 9 '19 at 12:45
Your house is not a space-ship, and it's not built like a space-ship.
If it's built anywhere close to a spaceship, you can run continuous ventilation fans, typically though an air-air heat exchanger. If it's of "normal construction" normal leakage will take care of adequate air exchange.
If you are adequately curious you can have a "blower door test" done to determine the actual leakage rate of your house under controlled conditions, which might inform both sealing particular leakage areas and the decision of whether or not to install active ventilation.
Yes, CO2 can build up.
I have a ductless mini-split system and recently replaced the door seals in my home. Working at home during this pandemic, there are three adults here in our 1700 square foot home almost 24/7. We have experienced a bit of drowsiness lately so I bought a CO2 monitor to check our air quality. CO2 level in our home was 1600 PPM! Opening a window about three inches with a bathroom ventilation fan running on the opposite end of the house got the level down to around 1000 ppm in about three hours.
Our CO2 level of 1600 ppm is not dangerous, but it’s high enough to be detrimental to mental acuity and possibly cause irritation and far exceeds the ASHRAE standard of 1000 ppm.
It’s hot here in the Arizona heat so opening windows to cool the outside air is going to get expensive; I’ll be airing out the house in early morning until I can install a heat-exchange ventilator.
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know the details of contributing here. – Daniel Griscom Aug 15 '20 at 11:22
There are two separate issues with any HVAC system and carbon dioxide (CO2):
Fuel Combustion
This is a concern with a system that burns oil, gas, coal, wood or anything else. There are specific requirements for ductwork in order to make sure it is not a problem. This does not apply to any electric system, including a typical HVAC system when cooling and a heat pump whether heating or cooling.
Humans
Humans inhale air including oxygen and exhale air including CO2. In a spaceship, this is a real concern because it must be sealed really well to prevent loss of air pressure, so CO2 will build up over time unless removed from the air through some mechanism.
However, a house on Earth is generally not sealed to an extent that normal usage, without additional CO2 from fuel combustion (furnace, gas cooking appliances, fireplaces, etc.), will not usually be a problem. It could be a problem in a well-sealed room, but even a room without windows will generally have some fresh air coming in from around the door, holes in the wall around receptacles, etc.
I found: https://www.ncbi.nlm.nih.gov/pubmed/26452168
This indicates that while the gaps around a bedroom door provide enough ventilation to prevent a dangerous situation from occurring, they do not provide enough ventilation to equalize the CO2 level between the bedroom and the rest of the house when sleeping, and the difference is large enough to cause perceptible differences in next-day performance.
Note that you don't need to ventilate between the bedroom and outdoors, but can ventilate between the bedroom and the rest of the house; there's enough leakage in a normal house that CO2 buildup is not a concern, just not within the confines of a bedroom. Leaving the bedroom door open a crack should be enough to equalize CO2 levels while inside.
    The creators of that study live in post-1990 homes. – Harper - Reinstate Monica Jul 8 '19 at 18:24
  • The simple fix is a transfer grille or jump duct between the bedroom and the adajcent hall, anyway – ThreePhaseEel Aug 15 '20 at 17:35
