I have a newly-installed shower that leaks like crazy. As soon as the water level exceeds the depth of the low-profile tray, I end up with water all over my bathroom floor.
Is this gap in the enclosure the culprit?:
shower tray
... and if so, do I just need a generous squirt of sealant or is there a component which our builder forgot?
(I'm also looking at why our trap is draining so slowly but that's another topic).
  • All this is something your installer needs to address, hopefully he is not paid in full yet to give him incentive to fix it, or at least a builder with integrity... – Jack Jul 20 '16 at 15:57
Yes, a shower base should be sufficiently water tight to contain an inch or so of water above the drain. I know that mine does. Yours doesn't appear to have a lip to contain the water, so that door needs a gasket to both contain the water and prevent damage to the door mechanism.
It sure looks like your builder forgot a seal or chunk of rubber gasket. If it's recent work, I'd definitely ask about it.
And sure, you want to have your drain running right, but all drains eventually clog. A working drain doesn't mitigate an unsealed shower base. You'll need it one day regardless.
