I have a Kitchenaid cooktop model KECC567 (5 burner model) with a 2 element burner that will not cycle on or off no matter what control switch setting is used. The 2 elements of the burner stay on continuously when the dual side is selected as does the single element when it is selected on the switch. I have replaced the infinite switch but the problem still exists. Appreciate some suggestions on resolution of this problem. Has to be a temperature sensor but don't know where to look for it. Thanks
  • Can you post the wiring diagram for your stove? (It should be on one of the inside panels somewhere) – ThreePhaseEel Jul 18 '16 at 0:29
  • How do you know the elements are suppposed to cycle? They may very well be designed to run at continuous current, not a set temperature point. Take a look at the owner's manual for starters. – Carl Witthoft Jul 18 '16 at 14:07
  • Burners needs to cycle on and off to prevent overheating the ceran glass cover similar to what the other 4 burners on the cooktop do. Turns out the infinite switch on the 2 coil burner was faulty. Thanks for your response. – Kelly Hawk Jul 19 '16 at 2:48
This is for future reference in case anyone is looking for similar information. The OP noted in a comment that
So, it should indeed cycle
P.S. Marking this CW since it isn't really my answer.
| improve this answer | |
-1
Well, I looked at the manual, at this site , and I see no indication that the power should ever cycle on/off. I think you misunderstand what the various settings levels do -- they just control the power level fed to the burners.
    That's correct but the burner needs to cycle on and off to prevent overheating the ceran glass cover similar to what the other 4 burners on the cooktop do. Turns out the infinite switch on the 2 coil burner was faulty. Thanks for your response. – Kelly Hawk Jul 19 '16 at 2:47
    @KellyHawk good to know. You should post that as an answer for future readers. I'll delete my answer after that. – Carl Witthoft Jul 19 '16 at 16:44
