I'm installing LED ceiling lights that come with analog low voltage control for dimming (i.e., 4 wire). However there is one existing sconce light that I hope to not replace. Would like it to also dim, but using 2 wire, leading edge control. I see a controller that offers all three types of controls but there appears to be toggle switches to select which. I'd like both simultaneously. Hoping the black is leading edge simultaneous with the low voltage. Basically don't know if the four wire control black is on continuously or leading edge switched.
The sconce is a standard screw in bulb socket. Currently with common CFI but the plan would be to switch to a dimmable LED bulb able to work on leading edge.
Yes, the analog low voltage is 0-10v (analog 4 wire).
  • Can I presume that said "analog low voltage control" is a 0-10V control? Jul 16, 2016 at 23:49
  • Also, what is the sconce light wired to already? Jul 17, 2016 at 0:34
  • Seems to me like you'll likely have issues with dimming rates, especially if the sconce is not LED with a similar driver.
    – Tyson
    Jul 17, 2016 at 0:43
  • @Tyson -- I think his best bet would be to use a regular dimmer and then use a dimmed hot -> 0-10V converter to drive the 0-10V(?) inputs on the LED driver Jul 17, 2016 at 13:06
My suggestion would be to use a garden-variety incandescent dimmer, connect the sconce light to it directly, then connect a Lutron GRX-TVI to it and use it to provide 0-10V to the LED driver.
  • Was not aware of the Lutron GRX-TVI product. Looks like a very interesting approach. I'll look seriously at it.
    – Paul M E
    Jul 18, 2016 at 17:03
  • Yes, it does look like that'd do the job. For residential, the $200 (amazon) price seems a bit steep, but at the moment appears to be the best option and there appear to be more competitive pricing other the the headline item.
    – Paul M E
    Jul 18, 2016 at 23:10
