Thinking of remodeling existing 11x 7 foot bathroom with bathtub & shower in one wet area. Not sure if the size of this area 5 ft x 4.5 ft is adequate, without resulting in having to clean the bathtub every time a shower is taken? What is a "recommended space " so that the bathub will not be splashed when only a shower is taken? Also concerned about if the shower drain will be adequate enough, without water overflowing into the rest of the bathroom ?
Your advice with these 2 questions will greatly be appreciated!
Thank You, George
