I have an in ground swimming pool. There is an outdoor sub panel with a 20amp GFCI breaker is connected to the pump. Today we had a bad rain storm...water coming down cats and dogs in every direction.
After the storm, I noticed my pool pump wasn't working. The breaker had tripped. I tried to turn it on, and it went off immediately.
So, I swapped out the breaker and the same thing happened....so it's not the breaker. Tomorrow, I am going to disconnect and wirenut the wires from the pump (disconnect the pump). If the breaker doesn't trip after that I will conclude there is a short in the wires running through the conduit...right?
Because it will be a pain to pull the wires and replace....which I am ok to run (temporarily, just to make sure it will work) the wires directly from the panel to the pump without putting them in the conduit right away. When I say "not right away" I mean long enough to make sure the breaker doesn't trip. If it doesn't trip then I would pull all the old wires and snake the new ones through.
I figured I would run this concept by the people here and get some feedback on this plan.
Thanks
