Goal:
I'd like to install a wall mounted shelf system in my bedroom. It's composed of vertical wood rails that screw into the wall, and then shelves and cabinets are hung off of the rails.
Background information and reference pictures:
I've already installed a section of the system successfully in my kitchen, which as far as I can tell is drywall- was fairly straightforward to install and I used the plastic drywall anchors that flip up to grip the wall (brand name 'wallclaw'.)
Picture of installation in kitchen drywall shown here:
Part of system I already installed in drywall
I am pretty sure that the bedroom where I want to install the remaining shelving is plaster, not drywall. I've read various advice on how to test this, but I'm still not sure. (I can insert a thumbtack in the wall, but it takes a little effort. Can't really tell from tapping the wall and listening. An inexpensive electronic studfinder has inconsistent results, a magnetic one only sticks in a few places.)
I had previously put a hole in a different wall in the target room, and found wood with a horizontal grain that is 'bouncy'- I'm guessing this is the slats plaster is adhered to and it means the entire room is plaster.
Picture of hole in a different wall in the target room:
is it plaster?
I purchased a higher end studfinder (Zircon Metalliscanner m40) and in wide scan mode I seem to have found studs 16" apart. When I scan vertically in pinpoint mode it seems to find a vertical row of nails- so I'm guessing this is where horizontal slats are nailed to the studs.
Question summary:
  • Given the evidence above, is the wall plaster, and not drywall?
  • If it is plaster and I don't want to go into studs, what anchors should I use- I'd like to put books and some heavy objects on the shelves and the weight is distributed between four 70" vertical rails, 32 inches part, with 4 screws in each rail (resulting in 3 "bays" of shelves in between the rails)
  • If it is indeed plaster and I want to screw into the studs, is the best way to drill a pilot hole then just go all the way through with a wood screw?
  • Am I correct that this means there are nails or screws throughout the entire height of the stud? If so, what is the best way to avoid hitting these with the screws when I attempt to screw the rails into the wall?
  • Anything else I need to worry about, like exposed wires behind the wall? (Plumbing is very unlikely given the room)
  • What's the best method to ensure the rails are perfectly parallel to each other and 90 degrees straight up and down?
    Wow Alex you are way over thinking this. If you want to put heavy stuff on the shelf you want to use the studs. measure everything and drill the pilot holes for your screws. If you hit something on one move them down 1/4" and drill new pilot holes. When you have your pilot holes drilled you should be good to hang your shelf. If for some reason you do not want to use the studs I would use a toggle bolt that flips open when inserted. I don't like anchors that expand on the back side that cant be removed (molly bolts). I normally use EZ anchors but not with lath & plaster. Your studs are the best
    Jul 13, 2016 at 20:03
Answers, in order.
  1. This is plaster and wood lath.
  2. Toggle bolts are typical, but the comment from @EdBeal about using the studs is spot on. Plaster is quite variable in its holding power... chances are fair that it wouldn't fail, but you can't be sure until you try.
  3. Forget the pilot hole unless you're having real problems driving the screw. The stud is softwood, so a pilot isn't necessary.
  4. The nails that attach the wood lath to the studs are tiny, so a screw will push past them. (Unless you're really unlucky and hit one dead-on-square in the middle, but that's very unlikely. Then reposition the screw a tiny bit up/down and do over.)
  5. You should always worry about electricity, but the chance of you drilling through a wire is relatively slim.
  6. Screw the top of one of the standards into the stud. Use a level to make it plumb and screw the bottom. With the level, mark the tops or bottoms of subsequent standards. Align to the mark, roughly plumb, screw one end, plumb for real, screw the other end. Repeat.
