My house was built in 1908 and still has its original plaster walls. One of the upstairs bedroom's wall has vertical cracks from floor to ceiling along the studs-3 studs in a row in the center of the room and another two studs from the corner. I had some plaster work done downstairs last summer and the plasterers were awesome-they showed me how to re anchor loose plaster so that's what I was going to do here. However, most of the other cracks I've had were diagonal and not so extensive. It makes me wonder what's going on behind the plaster to make cracks like these. I don't want to bother fixing them if there's a larger problem that should be addressed.
I'll add that our central air conditioner air handler is directly above this wall. Perhaps it's too heavy and is putting stress on the wall?
So, are the vertical cracks along the studs signs of a major problem or is it just a coincidence?
