I'm trying to get this mirror out without making a total mess of the surrounding drywall. Any best practices?
1 Answer
3 possibilities that I can see.
Tape every square inch of it and just start smashing. Wear serious eye protection and a face shield, gauntlet gloves, heavy clothing, head covering, ... in short, don't have any exposed skin.
Tape, protect yourself (as above), and try to get a pry bar under the edges. You'll need to do a bit of drywall repair, but you might get lucky and not have a pile of shards.
Buy (rent?) a specialty suction cup slide puller. (This is scary at the best of times and probably unavailable at normal rental...) Edit to add youtube link: https://www.youtube.com/watch?v=dQne8Caw1LI
1I might score a few lines to encourage it breaking into manageable rectangles as much as possible (then proceeed as in 1.). You could also try something cute with a standard puller, and something glued to the face of the mirror for it to pull on, rather than the hard-to-obtain suction cup puller. I'd do that on a center section after "tic-tac-toe" scoring in the hopes of popping that section out and having lots of edges to work with/from.– EcnerwalJul 9, 2016 at 16:06
2Went great with a combination of your first two suggestions- was too tight to get my pry bar in with any effect so I gave the top right corner a love tap to get things moving. With it all taped I gradually peeled it down piece by piece, prying off at the adhesion points. Thanks again! Jul 9, 2016 at 21:14
