I've ripped out the floor of my bathroom down to the joists. The bathroom is 5 ft x 4 ft. Should I use tongue and groove or can I use standard plywood? Does it matter?
Possible duplicate of Is it OK to use 1/4" concrete backer board over 1/2" plywood as a bathroom subfloor?– MazuraJul 8, 2016 at 4:02
The linked answer is about what backerboard manufacturers suggest to use at minimum. Were you looking for actual IRC code?– MazuraJul 8, 2016 at 4:04
@Mazura This sounds like his direct question is whether t+g is better than standard plywood. The other thread reads about concrete board. If I missed it let me know– ChrisJul 8, 2016 at 4:05
Backerboard is more important than using T&G or not, IMO. I'm not sure what code says; I just always use 3/4" (whatever) anyway, and not 5/8". - Wait... it's less than the size of a sheet of plywood. It wouldn't matter what type it is, except it's supposed to be exterior grade OSB.– MazuraJul 8, 2016 at 4:07
Backerboard provides no support, the important layer is the plywood which depends on joist spacing with a minimum of 1/2 required @16 oc w/ l/360– ChrisJul 8, 2016 at 4:10
Depending on the direction of the joists, it will only take 1 sheet, the T&G will have no value, unless the floor you pulled up was T&G as well, then it will only help on one edge.
If the T&G was cheaper than square edge, then I would use it. I have seen it cheaper in a big box store, although I could not figure out why it was. It was not on sale....
There are advantages to using t&g.
In terms of substrate requirements, it doesn't matter. A 5/8th sheet of t&g will support the floor just as well as a 5/8th sheet of standard.
For your considerations, with standard you'll have to space them with a 1/8th gap between sheets for expansion/contraction, this isn't a problem with t&g, they can be tightly fit.
14X5 bathroom - 4x8 sheet of plywood - ¿What joints? I hardly expect a pre-exsisting T or G joint right at the wall line where the old floor was ripped out...– EcnerwalJul 8, 2016 at 13:56
You said it yourself, it's a single sheet, and as such either a) Laxmidi has a T or G that he can tie in to, or b) he's overcomplicating the process. In either case my answer provides details on either situation.– ChrisJul 8, 2016 at 20:51
Since the subfloor goes down before the walls go up, the odds that a sheet lines up with the room are just about zero.– EcnerwalJul 8, 2016 at 22:22
