There's a leak in the PVC to PVC connection shown below. The pipe without red-lettering is not securely attached. It rotates slightly and can be pushed in and out slightly as well. I don't believe there's enough movement to pull it out completely as-is.
What's the best way to fix this? Specifically, where should I cut, and what can be re-used?
I am open to using the PVC primer and cement if recommended.
Leaky PVC connection
You'll want to try pulling it out - it would save a lot of headache if you could clean up and re-glue that joint.
There's small odds that you could cut the loose pipe short, then break out the remaining pipe in the fittings, and then clean the fitting up enough for re-use, if you can't just yank it out.
Otherwise you'll need all the fittings in the picture, plus 3 couplings (or unions, but those tend to be rare in PVC.) You 'll also need more pipe, as some will go for scrap with the fittings. A solvent-welded pipe is almost impossible to re-use.
You will also want PVC cement, AND primer AND cleaner. Dry everything well (if you can't, be sure to get special "wet use" cement - but try to dry it well...) Then clean both parts of the connection with the cleaner, and wait a minute; prime both parts with the primer, an wait as per directions (not too fast, but not so slowly it dries); then apply glue, as per directions, to both parts, and insert with a twist (1/4 turn is a typical goal) then hold them tight for a minute or so (they will try to push out somewhat due to the glue making the pipe expand a bit and the fittings being slightly tapered.) To get something like this where you are working in the middle together (without unions), you typically need to do at least one section of pipe on both ends at once, which is little tricky.
Or you can try to kludge it with rubber couplings (shudder, though it beats nothing for a temporary fix.)
Beware of old PVC cement - if it's not liquid, but has headed more to the "cold honey - taffy - brick" consistency, it's useless, even if you can still manage to spread it. New glue is cheap - buy small cans unless you have a large project in a short time, it does not keep well. It should be at least as runny as warm honey, probably a bit runnier.
  • Just confirming: If I were able to fully remove it, after I clean it I can treat it as a new pipe and cement it again?
    – jglouie
    Jul 8, 2016 at 1:40
  • Yes - while it won't be quite as nice to work with as actual new pipe/fitting, it can be made to work, and saves having to tear everything out and re-do it all.
    Jul 8, 2016 at 12:58
  • According to this study, using PVC Primer actually reduces the strength of the joint. If you want a stronger joint, skip the primer.
    – Gabe Evans
    Jul 8, 2016 at 19:54
    I see a few flaws in that study - compression is a mode of failure not normally seen, and they did not seat the pipes fully in the socket to allow this peculiar test to be performed. The latter, in particular, creates a joint that is far different than a standard, properly assembled joint, because the sockets are tapered.
    Jul 8, 2016 at 22:17
  • That may be true, but wouldn't the results of the tests translate, at least in part, to the conditions these pipes are normally subject to (complete insertion and all that)? Granted, the force required to break the joint would be much higher for one that was properly assembled than was demonstrated in the study, but I imagine that would apply equally to both primed and unprimed joints.
    – Gabe Evans
    Jul 9, 2016 at 4:28
Cut it about one foot back from the lose fitting.
Purchase one - 2" SLIP COUPLING. Which do not have a stop in the middle like standard fittings do.
When there's little to no available movement, you need to use slip couplings. These will allow you to (after applying primer and glue) slip it all the way over one pipe, to allow the other to swing into place. Then you slide it back so it's covering both.
When you go to re-glue everything, hold it as tight as you can for no less than a minute. I wouldn't be worried about the old glue mess; new solvent should take care of it.
  • Will the existing fitting be re-usable? Or that is to-be-determined?
    – jglouie
    Jul 8, 2016 at 1:50
  • @jglouie - It's going to want to push back at you something fierce. Hold it hard and steady until you're tired of holding it there, and then keep holding it some more. It'd better work, or you'll be replacing that whole elbow-tee section.
    – Mazura
    Jul 8, 2016 at 1:55
  • This is a good answer. I am marking the other as the answer because it contained the technique the plumber actually used
    – jglouie
    Jul 16, 2016 at 12:11
