I'm the proud owner of this guy:
http://www.cabinets.com/dsmw649h-mbc24-shaker-maple-bright-white-microwave-base-cabinet-1-drawer.html
The description is as follows (emphasis mine):
1 bottom drawer, 1 shelf included SHIPPED LOOSE with no shelf clips, the shelf is intended to be field installed to help hold the microwave, this cabinet is intended for built in microwaves not countertop microwaves, must field install microwave, this cabinet does not have finished interior, cut out dimensions are 14 13/16" high by 17 3/4" wide, maximum cut out is 15 13/16" high by 20 7/8" wide, premium UV finished plywood cabinet box construction, 1/2" plywood hanging rails, 5/8" solid maple english dovetail drawer box with BLUM motion integrated easy-close slides
​What kind of router and bit is warranted here in order to cleanly and straightly expand the hole?
  • Does your microwave come with any kind of a template? Jul 7, 2016 at 19:16
  • Not sure, I haven't gotten the microwave yet, but from its specsheet, I will have to cut the cab and I'm not sure which tool to use to do it right.
    – Matt
    Jul 7, 2016 at 19:18
  • It sounds like since there is already an opening and you'll just have to enlarge it a regular fixed router with a straight cutting bit could be use to open the hole. Depending on the material exactly, a downcut bit could make a nicer finish. I don't know that I'd use a mini or trim-router. Jul 7, 2016 at 19:20
  • Complicated answers -- whew! Cut close to the line with a jigsaw so you aren't taking too much with the router. Get a top bearing straight cutter (1/2" shank and cutter preferred, but whatever you've got...) Hot glue / carpet tape sticks to the outside (run each corner long in the same direction so you don't have to cut anything accurately). Router-router-router. Square your corners if needed. Reading this entire page took longer than the cutting operation! Jul 8, 2016 at 3:16
4 Answers 4
Straightly has entirely to do with your fence/guide, and there are many ways to do that. You can fence the baseplate, use collars and fence those, or use bearing bits and fence those - it's just a matter of offset from the cut line.
Cleanly is trickier, and depends on where you need clean. Solid wood trim would allow you to cover your sins, while trying to get a perfect cut on both sides of plywood might lead you to a (usually comparatively expensive) double-spiral (upshear and downshear on the same bit) to cut both faces into the middle.
Image from Amazon
A upshear from the backside or a downshear from the face side is most typical, but may result in tear out on the backside. Unless your guests look at the inside of the cabinet which should be hidden by the microwave being in it seeking tearout, no-one will ever know but you, normally.
I do wonder if the opening is already framed in solid wood strips, looking at the illustration. That would make it much less prone to tearout.
from cabinets.com link in OP
    Yes. The cabinet material will be a huge part, Also I would practice. Even after using my router 100 times I still mess crap up all the time, less so if I do a practice run right before the real thing.
    – DMoore
    Jul 7, 2016 at 20:52
Why are you using a router? Does your microwave overlap the edges? If so, I'd use a jigsaw, seems to me to be much easier set up.
    Great point! I should have specified I wanted to use this as an opportunity to learn to use the proper tool in case the cutout was not hidden.
    – Matt
    Jul 8, 2016 at 0:06
    @Matt - You can play with your router on your own time. Use a jigsaw ;)
    – Mazura
    Jul 8, 2016 at 0:45
The only problem with a router would be in the corners they will be rounded not totally square. A very small straight bit would give the smallest Chamfer (non square). This last fathers day my wife bought me this set of router bits I thought oh boy how long are these going to last I usually spend 15-20 per bit. The ones I have used have worked well, I mention this because you could a small bit in the corner then a larger one for the longer cuts. Make sure to use a guide or with a bearing tipped bit have some shims so you get the cut you want.
    Your wife knew what kind of router bits to get you? Holy crap +1 to the wife!
    – DMoore
    Jul 7, 2016 at 20:50
I'm assuming you mean want to expand the rectangular front cut out, and not some other hole. I think most hand-held routers would do the job. There is no need for a plunge feature in this operation, but you will want to guide the router along a straight edge to do a good job.
My first choice would be downward spiral ¼" straight bit, to eject the wood chips from the cut, in combination with a router template guide. This would allow you to follow a straightedge (e.g. straight board) clamped to the outside of the cabinet.
A normal ball-bearing guided straight flute bit could also work. These can be obtained with ball bearing guides on the top (or bottom) of the bit. The ball-bearing guide would allow you to follow a straightedge (e.g. straight board) clamped to the outside (or inside) of the cabinet.
