Need a new blade for an old RECORD 04 2" smoothing plane. Is there any significant difference between RECORD and STANLEY plane blades for similar size models STANLEY blades LOOK similar but I'm just wondering - would they be interchangeable
  • I have several electric hand planers and larger power planers. The big ones have groves or ridges to index the blades the smaller ones apear to be the same width and thickness and I have used different brands several times but the larger ones I would not try. – Ed Beal Jul 7 '16 at 1:32
  • woodworking.stackexchange.com – isherwood Jul 7 '16 at 16:50
They should be interchangeable.
You can buy a VERITAS PM-V11 BLADE FOR STANLEY & RECORD PLANES 2" which suggests the Stanley and Record designs are both very close to the original Leonard Bailey design.
Hock tools say *"Our 3/32" thick blades ... will fit 99.9% of Stanley and Record style planes with no modifications other than a simple frog adjustment."
For a different sized plane Paul Sellers wrote
Any 2 3/8″ iron, cap iron and lever cap will fit the No6. Stanley and Record will be interchangeable. It may end up costing you more than buying a complete No6 plane in the end though.
(my emphasis).
