A previous owner had drilled holes into the pvc frames to fit blinds, which have since been removed leaving small holes.
I'm not expecting pvc can be filled flawlessly, but what would be the best thing to do? White silicone?
White silicon may work to plug the holes but if you use it make sure to get the surface finish the way you want it before the stuff dries. It is not a material that will sand very well after the fact.
You may also want to try a bathroom tub and sink sealer product. These products bridge gaps fairly well and dry staying a nice white color. The product that I have used for sinks and tubs is the one pictured below.
Also be aware of several things. If screws had been applied into the PVC window frame the screw threads probably made a portion of the PVC surface stick out at the hole edge. This may need to be trimmed carefully so that your patched holes will be flat. If the window frame was made only of PVC with no internal wood structure the only thing the patch material will be adhering to is the edges of the hole. This will mean that the patch could pop in or out of someone were to be poking at it.
|improve this answer|||||
Basically i think you should just fill it with white Silicone. Simply position the pistol tip slightly above the drill hole and fill in the silicone material in the drill hole.
I think this will work perfectly for you, see http://www.window-frame.com/drilled_window_frame.php
Best regards maax
I had similar in a static caravan i bought, i used either similar sized screws with a plastic coated white head (Screwfix) or the plastic caps which snap over screws. To be honest, most look like they should be there, but depends on how many and how big the holes are
What you need is to use hard wax sticks. They can be bought online for about £3.00 ish and come in many different colours. Take a look here: https://www.youtube.com/watch?v=ftlYTtM4768
