I have an Ultra-Zone EWC-ST-2E controller unit for my gas AC unit at home (heating and cooling). It is set for two zones. Where the first zone has to be on (heating or cooling) in order to enable to operation of the second zone.
Both zones have Honeywell TH3110D1008 thermostats with the following pins: W, Y, G, O Rc, R, B, C
The first zone has the following wires in: W, Y, G, O, R, B The second zone has the following wires: W, Y, G, O, Rc
Is a Nest 3rd generation thermostat compatible with this setup/system?
Below are images of the main AC controller diagram and snapshot, as well as wiring of both zones.
Lastly, can anyone also explain what are the different wires for/meaning?
Here are more pictures of a pump or so that sits on teh floor next to the heaitng/cooling unit:
Here is a picture of the inside of the heating/cooling unit:
R
- 24VAC.W
- Heat call.Y
- Cool call.G
- Fan.O
- Heat pump changeover (cooling).B
- Heat pump changeover (heating).C
- Common (24 VAC). – Tester101 Jul 1 '16 at 22:05O
andB
wires are used with the zone1 thermostat, it doesn't appear you have a heat pump. Is the thermostat set up for a heat pump, or for a gas furnace with air conditioner? – Tester101 Jul 1 '16 at 23:23
