The designer of my compressor unfortunately didn't put a whole lot of thought into where to put the drain valve on it. It's on the back, and the compressor is against the wall, in a corner, usually with a mower or something backed up to it. Draining my compressor is a pain in the butt.
So I did something about it! I went out and get the appropriate adapters to have a hose coming out the bottom of the compressor and just loops around the top. Something like this.
   ________
 /   Motor  \   | |
 |__________|   | |
 /          \  ( x ) Drain valve
|            |  | |A
|            |  | |I
|    Tank    |  | |R
|            |  | |H
|            |  | |O
|            |  | |S
|            |  | |e
\____________/\_//Connection to old
 []        [] \_/ drain valve location
As you can see the water travels "up-hill". At first this doesn't sound right until you realize that the water travels "up-hill with 40-120 psi of pressure pushing it". I can't see a problem with this, but would love to know if there is some evidence that this is acceptable, or if this is a bad practice, given the cost of a new compressor.
As long as you purge the tank until the moisture out you should be fine. I maintain some big compressors 150-200 hp that all push up into a separator tank to make sure any oil is removed from the water then the oil drains back to the compressor and this is a commercial setup. I am guessing you have a manual valve, when there is very little water vapor coming out you should be good.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
