I'm setting up a dust collection system in my woodshop. It has lines that I mounted to the wall of 2" outer diameter PVC. I'm trying to connect one end of it to a flexible hose to use as a hand vacuum.
Common vacuum hose sizes close to this range seem to be 1 7/8" and 2 1/2".
I've found some rubber couplings that can connect to the 2" PVC, but the only options for sizes on the other end seem to be 1 1/2", 2", 3", etc.
Where can I find a proper 2" to 1 7/8" rubber coupling? Or a 2" to 1 1/2" coupling? Or is my best bet to just try to use the 2" to 2" coupling and connect it to the 1 7/8" hose?
