Problem: I had some old french doors removed and some new upvc bifold doors fitted. The french doors had a brick stub wall either side of the doors. My laminate floor was fitted up to the brick walls. With the walls now gone I have an 8 inch gap where I need my flooring extending.(see pic)
The floor in this pic was laid left to right and its click lock type. No Glue used . I have 2 spare packs of flooring ready to use.
The previous owner has laid the flooring throughout the ground floor with no breaks.
The floor extends to another 2 rooms to the right of the above pic and if I trace the boards back I think I'd need to pull the whole floor nearly plus the skirting boards,door frames etc.
Any ideas , tips ?
