So, I was changing a light switch and flipping circuit breakers to find the correct one. I accidentally flipped my AC circuit breaker off and then back on. After this I noticed the AC wasn't blowing cold anymore.
The fan inside runs, and air comes out the vents but it is not cold air. So I checked my outside air unit and sure enough, the fan is not spinning. I get a little stick and push the fan blades (in the right direction) and it takes off and begins spinning.
Okay so my capacitor is probably blown.
But still, it is not blowing cold air inside even after I take on the capicitor's job by "stick starting" the fan blades.
