How does one properly solder a 10 AWG copper stranded wire with an 18 AWG copper stranded wire. There are plenty of tutorials on how to solder same gauge wire, but what is the recommended way to solder wires that are significantly different AWG?
2If all you are looking to do is solder, what is wrong with twisting the strands together and soldering? The size of the conductor does not matter at all. Or am I missing something? – Speedy Petey Jun 26 '16 at 20:45
1What is the application that you can't use wire nuts/crimps/etc? – Speedy Petey Jun 26 '16 at 20:45
If this is power wiring for a device code states solder only connections are not allowed in the U.S. A wire nut is legal but why are you going from a high amperage wire 30a to a very low amperage wire? If the breaker is more than 150% of the device it would not meet code. If it is for a long run to reduce the voltage drop wire nuts or screw terminals could be legal. – Ed Beal Jun 26 '16 at 21:13
Backstory – Tester101 Jun 27 '16 at 14:51
If the wires are for low voltage application such as connecting 12V up to LED Strip lighting then you should consider just using twist on wire connectors instead of soldering. These have a decided advantage in that they can be removed for future wire changes and they provide an insulated cover over the wire join.
To keep strain off the low voltage wiring connections you can zip tie the two wire cables together over the cable jacket a couple of inches from the end of the jackets.
For low voltage applications, fan out the copper strands and then twist them together. Use rosin core solder. Tin the soldering gun (i.e, melt a little solder on it). Heat the copper and apply solder to the side opposite the heating implement. Let the solder melt and flow over the wires. (Melting on the side opposite the heat guarantees that the solder will really adhere to the copper, rather than just coat the outside.) Remove the heat and let it cool before moving it. You might want to slip a piece os shrink wrap tubing over one of the wires before you attach the wires. Then you can slip the shrink wrap over the solder connection and heat it so the shrink wrap tube shrinks.
