In the basement that I'm finishing I have an irregular, rough stone foundation wall, pretty dry. I'll use 1" XPS foam insulation, then drywall. Can I build the framing on the floor, attach the XPS to it directly, and then just raise the whole assembly snug against the foundation wall? Seems easier than attaching the XPS to the stone foundation.
Thanks for any insights here.
Jeff
