Hey everyone have a quick question regarding a honeywell VR8300A3500 Single Stage Heat Gas Valve and the introduction of a Ecobee3 wifi enabled thermostat with a "C" wire. just want to make sure i am understanding this correctly and have drawn out the right circuit. The TH/TR stand for TH- Thermostat and TR is the common correct? below is my drawn out circuit along with a picture of the valve and diagram of the valve. Thanks. Also i have a 24v hightemp switch in series as shown.
1 Answer
The only goof is that the 24V from the transformer is AC so it really doesn't have a + or - side to it -- it's more or less a "hot/neutral" thing instead. Otherwise, what you have drawn out will work just fine.
in the diagram? Typically,TR
represents the terminal that the transformer connects to, whileTH
is the terminal the thermostat connects to.
