I just shifted to new house and I plugged in the surge protector that I use for my PC into one of the sockets.
The socket switch was off, while the main circuit was on (main power). And the surge protector shows three lights - indicating L and N reverse; and Open Neutral.
Then I plugged the surge protector in all sockets in my house and all shows the same status. This indicator shows the same status irrespective is the socket switch whether OFF or ON
Is it normal? Should I avoid using appliances? (until corrected)
