It's time to replace my anode rod and I'm not sure what type I should get (Magnesium, Aluminum, Combination, or Powered). I have a well and use a water softener. I have a high iron content (orange stains in toilet tanks and in showers) and I've just started adding rust-remover pellets to the softener. There is also a very slight rotten-egg smell to the water. I don't think the anode has been changed in many years. What type of anode rod should I get?
It depends on how much you want to spend, how old your water heater is and what kind of water you have. The aluminum rods are usually the cheapest followed by magnesium. The combination rods I don't have much faith in as the least noble metal is eaten away first. powered rods that will last a lifetime are very expensive due to the platinum wire used. Your water is high in mineral content the Iron and possibly sulfur (rotten egg smell) so Magnesium would be the most cost effective. (with Low mineral content Aluminum would be the way I would go). I did have a P wire system on a metal boat instead of anodes it worked well and I no longer had to change out several a year but a water heater I think P wire systems are overkill on a home system. Make sure to turn off the water heater and flush it when installing the new anode this may help reduce the smell. Water heaters tend to last for ~10 years some 15+ so if you are at the upper end of the life scale you may want to go with the cheaper anode. Once the damage is done there is no way to reverse it.
    This is a great answer but I think the phrase "at the upper end of the scale" may lead to confusion. Do you mean to refer to a 15+ year WH as opposed to a ~10 year? The context would indicate that you mean nearing the end of the WH's anticipated lifetime. Jun 14, 2016 at 19:55
    I have seen some old ones last 20 years but in the last few years it has been more like 10 years with the cheaper big box units and maybe 15 for the higher quality ones. I was trying to say with a unit that is at the upper end of normal life it may not be worth it to get a expensive anode.
    Jun 14, 2016 at 20:21
  • Water heaters and anode rods are rated for the number of years; more years = more material in them, to be eaten away instead of the hot water heater shell and pipes. Best to replace the anode rod on a schedule, before it wears out and the heater shell or pipes corrode. Jun 13, 2023 at 15:27
