If I use a submersible 1/2 HP pump to empty standing water that is full of leaves, the pump's intake gets clogged so often that the process is considerably slowed down.
Two ideas can solve this problem.
- Build—or better yet, buy—some kind of filter cage. I'm thinking of putting a mosquito net around a small plastic crate. Do I really have to DIY this, or is something similar available on the market? If it is, please provide a search keyword.
- Built—or better yet, buy—some kind of hose filter. A hose submerged gets clogged in no time from the leaves. I built a small trinket that does this trick, but it's fiddly and needs fixing often. I wrapped mosquito net around the opening of a small plastic box and shoved one end of the hose in the base of the box. Is something of this sort available commercially?
