Just bought an air compressor, and when I turn it on it starts to build up air but when it gets to around 20 psi the motor seems to be slowing down almost to a stop. Does anyone know what's up with this?
1Sounds like a candidate for a return to the store. – ArchonOSX Jun 10 '16 at 16:03
Yes just bought it yesterday.... – Scooter Jun 10 '16 at 16:52
Well I figured it out the compressor wasn't getting enuff power .... thank you for your help – Scooter Jun 10 '16 at 17:29
Have you tried the compressor on a different circuit (and without an extension cord)? This might point to house wiring issues. (I'm also assuming you're not in a very cold climate, as that can make compressors sluggish.) – Aloysius Defenestrate Jun 11 '16 at 14:17
This is the same thing that happens when you use an extension cord of insufficient gauge to power a compressor, as you say, it's insufficient power. Of course, it will try to pull sufficient power, and if it succeeds, probably light the extension cord on fire.
