The gap is due to paneling install over drywall and I am re-installing trim around windows and door. The trim only has clear coat, so painting caulking does not appear to be a solution here.
    A picture of your conditions would be really helpful
    – Jack
    Jun 7, 2016 at 3:17
Most silicone caulk manufacturers make caulks in a handful of tan colors:
If none of those colors match well enough, you could try looking for some wood putty. Some putty dries hard; some doesn't. Here's one possibility.
  • Note that ALEX is acrylic latex with a little silicone added. It's not silicone, per se, which isn't paintable.
    Jul 5, 2023 at 18:53
