I have a Zinsko outdoor panel with a 100 amp breaker for the garage and 125 amp breaker for the cottage. The breakers are bad, so checked into replacing them. It seems a Zinco or Connecticut electric breaker is $175 or more each as compared to any other brand that are about $50 each.
Wondering what the difference is between these breakers and inexpensive breakers, zinas I'm contemplating replacing the panel and breakers with Siemens, Square D, etc., as panel and breakers would be $200 total. And if the breakers need to be replaced again due to being near salt water ocean, cost would be 1/3 of a $175 breaker.
