I purchased a single pole boring light switch to replace a not-really-used dimmer, and I want to be cautious and check myself. I apologize if this is a duh question.
The guides all show switches that have one set of wires, or show a switch that is labeled. I have two sets of wires, and my switch just has two identical, unlabeled looking screws on one side and a ground on the other.
To describe the picture...
- The white are connected to each other
- The ground are connected to each other.
- The black (dark green?) are connected each in turn to a wire off of the switch with nuts
Should I just undo the black wires and screw them to either of the copper screws on the new switch? Does the order matter? What about the ground, right now, the two grounds are just lumped together in the box.
