How can I repair an electing ignition on a gas stove that is intermittent?
1Make and model?– Daniel GriscomJun 2, 2016 at 1:57
1Replace the igniter?– RedGrittyBrickJun 2, 2016 at 12:57
1Are the electrodes clean? including the area on the burner it arcs to? buildup can be an insulator or sometimes a short reducing the arc.– Ed BealJun 2, 2016 at 13:17
1There are several types of selectively ignition (piezo, mains/battery powered spam generator). Which do you have? Piezo normally has a dedicated button which you have to push quite firmly, and doesn't need a power source.– Chris HJun 2, 2016 at 16:39
1 Answer
You didn't specify what is the failure mode of the unit..!! Did you changed its battery? Assuming its using battery, check for corrosion at battery holder/contacts.
High voltage spark points may have carbon or any other residue which might shorting out the arc. If its using piezoelectric generator (battery not used) very likely it may have shorted path in its high voltage side causing intermittent operations.
Electronic type using battery and boost converter. Any failure in this sections requires knowledge in electronics in order to repair it.
Also, the burner's flame spreader should be removed and checked for alignment with the igniter. If it is cockeyed, it limits the spark.– wallykOct 1, 2016 at 16:43
