I have the following water pressure gauge.
I need to connect it to the garden valve, but not sure which adapters I would need.
Something like this:
    If your in the USA, Home Depot and Lowes both have what you need. I won't specify which parts because you may need to modify slightly if somethings out of stock. Also Home Depot stocks that gauge (probably Lowes as well) with a 3/4 hose fitting for $10.. I bet the combination of fittings needed will add up to almost that.
    – Tyson
    Jun 1 '16 at 20:36
  • I agree with Tyson. Most hardware/home improvement stores will carry a gauge that has a 3/4 GHT fitting already on it. And it's likely cheaper to buy that, than to buy the fittings you need.
    – Tester101
    Jun 1 '16 at 21:50
    Here's a 3/4 FHT to 1/4 FPT adapter gor $7.42.
    – Tester101
    Jun 1 '16 at 22:00
    Here's one for $5. And the gauge sold at HD
    – Tester101
    Jun 2 '16 at 13:54
