This question already has an answer here:
I am looking to take a portable AC unit and hopefully run a tube through a wall in another room while still cooling the room the unit is located. I have searched to attachments that could help but have come up empty. Any help would be appreciated.
DR
marked as duplicate by Tester101 Jun 1 '16 at 14:29
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    In my experience with a portable A/C unit, the cooling power was so anemic that it couldn't even cool one room, let alone two. – Johnny Jun 1 '16 at 4:12
Any way of circulating the air between the rooms will help, although I doubt you will be able to achieve uniform temperatures. Put the AC in the room that is hotter (e.g. has more windows) and then do the best you can with a fan or two.
Also, make sure the AC is properly sized for the area you want to cool.
