The National Electrical Code requires that all habitable rooms and bathrooms, have a switch controlled light (210.70(A)(1)). It also allows a switched receptacle to be used, instead of a lighting outlet (210.70(A)(1)EX.1).
Later in the code, it requires a grounded (neutral) conductor at switch locations that control lighting loads. However, it does not require a grounded (neutral) conductor, where the switch controls "a receptacle load".
So if a room uses switch controlled receptacles to meet the switch controlled light requirement, is the grounded (neutral) conductor required at the switch?
Relevant code text
National Electrical Code 2014
Chapter 2 Wiring and Protection
Article 210 Branch Circuits
210.70 Lighting Outlets Required. Lighting outlets shall be installed where specified in 210.70(A), (B), and (C).
(A) Dwelling Units. In dwelling units, lighting outlets shall be installed in accordance with 210.70(A)(1), (A)(2), and (A)(3).
(1) Habitable Rooms. At least one wall switch-controlled lighting outlet shall be installed in every habitable room and bathroom.
Exception No. 1: In other than kitchens and bathrooms, one or more receptacles controlled by a wall switch shall be permitted in lieu of lighting outlets.
Chapter 4 Equipment for General Use
Article 404 Switches
404.2 Switch Connections.
(C) Switches Controlling Lighting Loads. The grounded circuit conductor for the controlled lighting circuit shall be provided at the location where switches control lighting loads that are supplied by a grounded general-purpose branch circuit for other than the following:
(7) Where a switch controls a receptacle load.
