If you have a sliding patio door with a Euro cylinder lock in it, it probably opens from both sides. If you only wanted opening from the INSIDE, could you replace the cylinder with a half cylinder and blank off the outside hole? I'm thinking of this from a security perspective, so that there is no outside cylinder that might be attacked.
Realistically, the door can't be opened from the outside due to other locks anyway.
    If you're only opening from the inside, why a lock at all? You want a simple dead-bolt actuator, since without a key there's no reason for a cylinder. Commented May 31, 2016 at 15:35
  • @CarlWitthoft Err, what's a dead-bolt actuator? Is it electric?
    – Paul Uszak
    Commented Jun 1, 2016 at 21:40
  • No, just a simple lever or knob as on a typical keyed deadbolt. Commented Jun 2, 2016 at 11:34
  • @CarlWitthoft Carl, it's a sliding door so I'm not sure how that could work.
    – Paul Uszak
    Commented Jun 3, 2016 at 12:41
