I am expanding the deck that goes very far (35 x 48 feet ~ 1000 sqft). So I am pretty sure the further end will not perfectly parallel to the house. It could be 1-2 inch off from one end to the other end.
Imagine a scenario like this:
If I start to install the composite decking starting from the house, the one near the last board will end up like the red rectangle in the photo. So should I cut the last board in a weird way (one end is shorter than the other end)?
It's composite decking board so I cannot "play" with the gaps by having larger gaps or something like that. So I came up with few options:
Option 1:
I am thinking about doing the "picture frame" method around the edges by installing #1 and #2. Then at the end, I will install #3 (as photo below). But then I am wondering how many inches a composite decking board and "hangover" the edge of the trim joists?
Option 2:
Without using picture frame method, I would start installing the boards from the further end of the house. This will result in the odd looking board near the house right at the foot step. I am assuming it's "harder" to see the imperfection this way?
What would be the best cosmetic way to manage situation like this?
