How many 5 metre strips of 5050 LED lighting will a 6 amp driver feed without overheating?
I think this might belong in the electrical engineering SE, but perhaps you could add some details about the driver and lights... I'm not really familiar with LED drivers, but anyone who was would probably skip over this question because it lacks information like how much current the lighting draws and the make/model of the driver. Specification sheets for the driver might have that information.– Ben WelbornJun 7, 2016 at 21:21
1 Answer
One.
Presuming you're dealing with 12 V and a 300 light strip.
A not entirely universal rule of thumb is 150 lights per amp for 3528's and 50 per amp for 5050s. That is because 5050s have three emitters per light and each of the three draw about as much as a whole 3528. If you're using 24V strips, double the number of lights per amp. Of course, check your data sheets and/or put it on a power supply and test it.
