I would like to change the light setup in my garage. Right now there is one switch that controls 3 lights, I would like to change to 3 Switchs that controls 6 lights.... 2 lights per one switch, can you show me a simple way to do this
    Can you post photos and/or a diagram of the existing setup? Also, where do you want to put the switches and lights, and are the garage walls finished or not? – ThreePhaseEel May 28 '16 at 4:56
  • This is really easy take power to each of the 2 lights from 1 switch or 3 total if this is two complex hire a electrician . – Ed Beal May 28 '16 at 7:56
Take power to each switch. Then feed neutral, ground, and a switched hot to each set of lights.
Grounds not shown for simplicity
