I have Anderson casement windows I want to rehang because some sashes are rubbing up against the bottom or side. I think the rubbing is just from the sash sagging over time, they were installed in 1970. I'm having a hard time keeping the sash centered while I screw the hinges in.
Any tips or methods for hanging a sash? Should I replace any parts while I'm at it?
  • How about a pic? Are you replacing the hinges? How about the casement operators? Are you going to strip all the old layers of paint and refinish? Commented May 26, 2016 at 4:49
  • I was going to keep the hardware but I could replace it. The sashes are old so I've had to buy replacement parts from retailers other than Anderson. I once removed a sash and tried to rehang it but I had a problem keeping it square within the opening. Should i shim around the sash while screwing in the hinges? Do I attach the sash when the window is in the closed position? Commented Jun 28, 2016 at 14:43
