Installing a bathroom vanity cabinet. It fits fine, but I need to cut a half inch of the base board tile (tile along the wall, where it meets floor tile) to have the cabinet flush to the wall. I recently bought a Bosch 2608661757 Grout and Mortar Remover for my Oscillating tool to remove a layer of grout to regrout floor. Will I be able to use this accessory to cut this tile on the wall? Trying not to go buy another saw. I also have other saw bits, but would like some advice.
  • How much tile do you need to cut?
    – JPhi1618
    May 20, 2016 at 16:30
  • It is one tile and a half inch needs to come off a 2"x4" tile, on the wall May 20, 2016 at 17:20
  • Wouldn't it be better to cut the cabinet to fit the tile? Or is the cabinet concrete or rock, etc.?
    – wallyk
    May 20, 2016 at 17:24
  • Wow, that was an angle I did not think about. I have to check the cabinet when I get home from work. May 20, 2016 at 18:12
That should cut through the tile fairly well (assuming ceramic and not porcelain), but it may not leave a clean edge against the cabinet. In particular, you'll have trouble getting through the surface glazing.
I'd set the cabinet in place, trace it on the tile with a permanent marker, pop the tile off the wall, and take it to a big box or tile shop and ask them to cut it with their wet saw.
  • Sounds good. Thanks for that advice. Did not think of the edge it would leave with that tool. Was looking for a quick solution, but it would have looked horrible and I could not find those tiles around. May 20, 2016 at 17:32
  • Wet saw is the best way to cut it will leave the cleanest edge.+
    May 20, 2016 at 20:05
  • Note that "pop the tile off the wall" might result in breaking the tile. Hope you have spares. May 21, 2016 at 1:17
