Frigidaire FED355 Electric range. Oven and stove-top in use, heard loud 'Phump', and it all goes dead, clock, lights, etc. Warm plastic aroma. Reset breaker. Range top lights, clock, timer now work.
No fault or error codes.
Can set oven temperature or broiler high/ low, relay clicks, but no heat on either element.
Voltage at elements shows 120v to ground from each leg, but 0 between the two legs.
Also, any sources for diagram to remove board? I've pulled most every panel, sides, top, rear, but can't remove front control panel. Thanks.
