I'm going to be treating beechwood counter tops with linseed oil (following these instructions).
The person in control of the budget has asked me to figure out how much oil will be required (so we don't buy too much).
The tops are 40mm deep.
How many ml of oil should be used to give a single coat to a 1000mm × 1000mm × 40mm block of beechwood?
I am assuming it will be the same amount for each coat, so let me know if that assumption is wrong.
Is there a heuristic I can use to work it out for other thicknesses?
Given that, I can figure out the total required from the number of coats and reapplications.
  • What sizes is the linseed oil available in for you? Easy answer would be "a quart is plenty for that top", so are you trying to buy smaller amounts?
    – JPhi1618
    Commented May 13, 2016 at 15:15
    Frequently the product packaging will have a recommended coverage.
    – BMitch
  • I can buy anything from 250ml upwards. There are even 4000ml cartons on Google.
    – Matt Ellen
    Commented May 13, 2016 at 15:17
    Will you be cutting/preparing food directly on the countertop, or not? Reason for asking - almost all "boiled" linseed oil is not boiled, it's got "drying chemicals" which are typically some sort of heavy metals. And raw simply does not dry. For non-nut-allergy and food contact, I use walnut oil (which dries); otherwise mineral oil, which does not dry, but which does not go rancid, and is easily recoated as a maintenance routine.
    Commented May 13, 2016 at 16:20
  • The tops will be used for working on electronics (soldering, etc.).
    – Matt Ellen
    Commented May 13, 2016 at 16:59
The oil that you use (or are thinking of buying) will typically list the coverage on the package or instructions as BMitch suggested in the comments.
For instance, on the website you linked to for the instructions, they sell this (randomly chosen by me, no endorsement) counter top oil, and in the description it says:
One litre covers approximately 13 square metres per coat. It is touch dry within one hour and can be recoated within three hours depending on temperature and humidity.
So this 500ml can will cover 6.5 square meters, or give your 1 square meter surface about 3 coats. You mention the depth of the counter top, but that shouldn't matter. The oil is largely a surface treatment, and the coverage will not change based on the thickness of the wood.
It's been my experience that the first coat might "soak in" more than the additional coats, so the coverage won't be as high as advertised. In the case of this oil, I would worry that a 250ml can wouldn't be quite enough, so I'd get a 500ml and feel good about having some extra for later.
Of course, look at the coverage on the oil that you want to buy and do the calculations for yourself.
