I have two bedrooms and a shared bath that are on one circuit. Through some initial remodeling/updating, all of the outlets were replaced (3-prong), and all of the light switches. All is fine in bedroom 1 (outlets work, light works). Bedroom 2 nothing works, and bathroom lights don't work, BUT the GFCI in the bathroom does work. Breaker not tripped.
I checked all of the connections and all are tight (not stabbed, but wound around the screws). I purchased a plug-in receptacle tester, and every outlet shows up as wired correctly. I also tried a voltage tester (the pen that beeps and blinks red) and it shows that all are receiving voltage.
Does anyone have any ideas what the problem could be? Thanks so much for the help in troubleshooting.
