I have an old chair that part of broke of some time ago and was lost. I've finally got round to fixing it as it's a bit of an eyesore. I started by using some woodfiller which I had lying around, but after not putting too much on I thought that this might not be the best approach.
My current thoughts were to use some more filler and then sand it down to the correct shape. But once I have done that, how would I paint/varnish it to get the same colour as the rest of the chair? Is there a better approach one can take to complete this? It is worth noting that I am defiantly an amateur and don't have a whole ton of tools.
Edit
The arm is still fixed on solidly and supports my arm just fine. So this is just for cosmetic purpose.
