From what I understand there are 3 ways to wire a bathroom fan:
  1. Together with the lights (both are on or off);
  2. Individual switches for lights and fan;
  3. Put the fan (and maybe the light) on a presence sensor (which usually have a timer).
Now what I would like is to have a switch to turn the fan on and when the switch is turned off it remains on for a while. Is there a way to setup that?
12
    Can you explain why you'd want the 'delayed off' switch rather than your standard timer switch? I'm not sure if what you are looking for actually exists.
    – DA01
    May 7 '16 at 15:56
  • Because my wife asked if it was possible. She doesn't like that the fan turns on every time someone just enters the bathroom (the 3 setup above). I don't know enough to know if this is feasible... May 7 '16 at 16:24
    So what you want is your option #1, but with a delayed off in the fan circuit?
    May 7 '16 at 16:30
  • @FreeMan Yes, something like that. May 7 '16 at 16:35
    If the wiring is there to support it (separate switched hot for light and fan), a humidity sensing switch could be installed for the fan. Then the fan will automatically run whenever the humidity in the room is too high.
    – Tester101
    May 7 '16 at 17:51
There's no such thing as too many wires between the bathroom switch and the bathroom light/fan/heatlamp/whatever the future may bring. I would run at least 3 hots and a neutral, with 1 hot and 1 neutral being 12ga for a high current device. Even better, install conduit and pull whatever as needed.
I personally hate fans which turn on with the light. I fear I'll wake others during a 3AM bathroom run. It also wastes energy by ejecting nice warm/cool air, forcing the HVAC system to work harder.
This forum is not for "shop for you", but there's no problem getting a single switch that turns off the fan some period after it turns off the light. the fan with a delay. on light+fan, and turns off light and adand continues the fan for a designated period.
There's also no trouble getting rundown timer switches if you want to manually trigger the fan. However if you also have a heatlamp (commonly put on rundown timers), this will be a confusing UI.
They even make fan controls which detect humidity. The question is whether they have, um... VOC detection.
Amazon links on SE pay a tiny commission to somebody, possibly me. It biases me toward linking products sold on Amazon.
