Water leaks from the valve when the water to the faucet is on. What is the name of this type of faucet & how do I fix this leak? I put in a new washer in the garden hose which stopped the hose from leaking but it's still leaking from the faucet valve.
Pictures here: https://i.sstatic.net/6EDXF.jpg
I would replace the entire sillcock (also called a stopcock, outdoor faucet, hose faucet, or spigot), because it looks like you lost the handle, too; in which case you should watch this video: https://www.youtube.com/watch?v=Lj_nTbIWzfI,
Or if you really intend to repair it, try this instead: https://www.youtube.com/watch?v=cALQ3PR7k30
Edit- One important tip that I should add about installing or replacing the sillcock- it should lean downward as it exits the building. The reason that sillcocks are long is so that the important parts (the actual valve with rubber gaskets or rings) can be protected from freezing (by being inside the building). And it needs to lean downward so that it can drain or else it will have water inside the valve body that can freeze.
Edit2- In response to your comment, there is no "type" in the way that you are thinking of this. I prefer to call it a sillcock. It may have a long valve/valve body, or a short one. Unless you see the manufacturers brand name on it, nobody could guess, and it makes no difference.
The only way to know what you need is to take it apart. The bad gasket or rings should be obvious. Perhaps you can find replacement parts at a hardware store (or online). See the picture showing how to take this apart; be sure to turn off the (main) water before you take the sillcock apart. You may also need to use the sillcock key to unscrew the valve assembly. Once you have the valve assembly out, take it with you to the hardware store so that you purchase the correct size gasket(s) or whatever you need.
  • Both the front & rear outdoor faucets didnt have handles when I bought the house. I went to Home Depot and the only successful fix I found was to use a 4 way sillcock key. So what is this type of faucet so I know which replacement washers to order?
    – catjacent
    Commented May 4, 2016 at 23:30
  • @catjacent I made an edit in response to your comment. Commented May 5, 2016 at 13:26
