Hi my old coal store in cellar leaks ground water when it rains. Rest of my cellar is a converted kitchen and bathroom. House is over 100 years old. I have damp proofed with liquid rubber, tanking tar and epdm. Still leaking. Its not major water but causes a puddle and walls and ceilings have droplets of water. Its also freezing. The store is tall enough to stand in more like a small room with a door. Outside above the store is concreted to front of house. If i block the room up with a wall will water just seep through bricks over winter months or is this the best option? Thanks
    You can't fix this from the inside, you need to divert the water away from the outside. – Tyson May 2 '16 at 12:36
  • Can you clarify what a "coal store" is? A freestanding container of some sort? What material is it made of? If the ceilings and walls of the basement have moisture, then that's condensation due to cold, and only a dehumidifier will help. Does water only get in when there's rain -- i.e. thru a leak in the exterior part of the store? – Carl Witthoft May 2 '16 at 12:54
