Started what I thought was an easy job of placing "peel and stick" tile and grout in my downstairs bathroom, but that was until I removed the quarter round at the base of the tub.
dryrot
It is not all the way through. I've been under the house to check, plus I cannot poke through it with a screwdriver.
What can I do here? It is such a small area that I'm not enthusiastic about laying new subfloor.
  • that is really not as bad as most I have worked on. Since you want to put tile down I would fill the area with thinset or a mortar, let it cure and your base for the tile should be fine. It looks like you have removed all the bad wood so you should be good to go.
    May 1, 2016 at 20:34
  • The tile I'm using is vinyl stick-on. I definitely would like to keep most of the laminate as it would be ideal padding. You're the second person to suggest doing a fill. Someone told me to do self-leveling compound. May 2, 2016 at 17:28
    In a bathroom that's not likely "dry rot". It's just rot (due to moisture). Make sure you address that problem as well.
    May 2, 2016 at 17:38
  • @isherwood I know where the moisture came from. A toddler bathed in this bathtub and had a tendency to splash. There was an attempt to caulk, but it was most likely too late. May 2, 2016 at 17:45
Yick, we had something similar but worse. I: Cut out whatever subfloor was gone. The joists were stained and powdery looking in spots, so to prevent any mold colonies I painted those up to the edges of the remaining subfloor material with Kilz. When that was dry, I screwed in pieces of matching plywood to replace the gaps, noting that I made sure to have all edges secured over the joists - no pieces with hanging edges short of the joists. I then painted everything I replaced on the exposed subfloor with Kilz, going on the idea that if it seeped once, it could seep again someday.
(Replacing the entire floor - once I had 1/2" plywood down, replaced where needed, I went over that with 1/4", which made sure no repair seams showed through the flooring over time.)
